[mapguide-internals] Rfc 21 posted
Paul Spencer
pspencer at dmsolutions.ca
Mon Jun 4 06:55:44 EDT 2007
Thanks Kenneth. I guess I have the viewer implementation that is the
exception :) One of the things Fusion has is the ability to switch
map definitions within the current session, a kind of basic support
for themes I guess, and also to have more than one map in the viewer
as well, so this compatibility is important to me :)
Cheers
Paul
On 2-Jun-07, at 2:35 PM, Kenneth, GEOGRAF A/S wrote:
> Yes, they take into account that you can have any number of runtime
> maps.
> The current viewer implementations only create one runtime map, and
> always name the map:
> "Session:" + sessionId + "//" + mapName + ".Map"
> The security system should not allow one session to interfere with
> another session (except for administrators).
> I belive that the system works like this already.
> I have updated the Rfc, so the mapName parameter is now a full
> MgResourceIdentifier, rather than just the map name.
> This will ensure that it can read/write a runtime map of any name,
> including the naming scheme currently used.
> Regards, GEOGRAF A/S
> Paul Spencer wrote:
>> Personally, I would only want it to affect a specific map within a
>> specific session. I believe it is possible to have more than one
>> map in the session based on the same map definition and I think
>> this should only affect the specifically named map. It certainly
>> should not affect other users in other sessions.
>> Cheers
>> Paul
>> On 31-May-07, at 7:34 PM, Walt Welton-Lair wrote:
>>> Do these new APIs take into account the caller's session? You can
>>> have
>>> multiple users viewing the same map definition, and therefore
>>> there are
>>> multiple runtime maps associated with that map definition (each
>>> part of
>>> a different session).
>>> I also can't remember - is it possible to have two runtime maps
>>> for the
>>> same map definition within a single session?
>>> Walt
>>> -----Original Message-----
>>> From: mapguide-internals-bounces at lists.osgeo.org
>>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of
>>> Bruce
>>> Dechant
>>> Sent: Friday, June 01, 2007 1:10 AM
>>> To: MapGuide Internals Mail List
>>> Subject: RE: [mapguide-internals] Rfc 21 posted
>>> Here are my comments.
>>> In the APIs below there is no need for the "mapName" parameter
>>> because
>>> everything is already contained in the underlying map resource
>>> referenced by the MgResourceIdentifier so the parameter is
>>> redundant:
>>> void MgMap::UpdateRuntimeMap(MgResourceService* resourceService,
>>> MgResourceIdentifier* mapDefinition, CREFSTRING mapName); void
>>> MgMap::UpdateMapDefinition(MgResourceService* resourceService,
>>> For the other proposed APIs below the "mapName" parameter should be
>>> replaced with the MgResourceIdentifier because we do operations with
>>> resource IDs:
>>> MgByteReader* mapDefinitionAsXml, CREFSTRING mapName);
>>> MgByteReader* MgMap::MapDefinitionFromRuntimeMap(MgResourceService*
>>> resourceService, CREFSTRING mapName); void
>>> MgMap::CreateMap(MgResourceService* resourceService, MgByteReader*
>>> Thanks,
>>> Bruce
>>> Sent: May 29, 2007 2:56 AM
>>> Subject: [mapguide-internals] Rfc 21 posted
>>> I have posted a Rfc.
>>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc21
>>> --Regards, Kenneth, GEOGRAF A/S
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> |Paul Spencer pspencer at dmsolutions.ca |
>> |Chief Technology Officer |
>> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals
