[mapguide-internals] MAP Spatial Filter
Haris Kurtagic haris at sl-king.com
Fri Jun 8 03:27:56 EDT 2007
I have a question what is way that MG will set spatial filter when in
Map there are layers with different coordinate system's.
I have in test Map layer with Lat/Lon and layers with projected cs.
MG when querying is sending same extents of Map for both layers geodetic
and projected.
So when querying against Lat/lon layer MG is setting spatial filter to
extend in projected coordinates.
I suppose this is not how it should work ?
P.S.
Another issue I had is that if for example in Map There is just one
layer with geoditc cs, Map will set filter bigger than (
-180,-90,180,90).
Thanks,
Haris
More information about the mapguide-internals mailing list
