[mapguide-internals] Custom line style
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Jun 11 09:47:05 EDT 2007
Custom line styles are not currently supported. But see this RFC:
https://trac.osgeo.org/mapguide/wiki/MapGuideRfc14. The line
symbolization portion of this RFC will give you what you need.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Stefan
Dalakov
Sent: Monday, June 11, 2007 3:09 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Custom line style
Hi all,
Is it possible to create custom line styles to use with Mapguide OS ? I
have a project which is very sensitive on the way lines are represented
- should conform to some standard specifications and need to find a way
to implement them.
Thanks in advance
Stefan Dalakov
MapWare Ltd
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
