[mapguide-internals] Release of MGOS 1.2.0
Thu Jun 28 16:50:14 EDT 2007
Bruce Dechant wrote:
> Multiple threads should not be accessing the GDAL provider concurrently,
> however, when one thread is finished another thread can start to use the
> GDAL provider and hence the same cached FDO connection. This might be
> the "multiple" threads you are seeing. Is it not safe for the server to
> reuse an existing GDAL FDO connection via one thread at a time or is it
> safer to always start with a brand new GDAL FDO connection?
Bruce,
It is fine for different threads to use a given connection as long
as it is serialized.  Haris, does what Bruce is saying above jive
with the way you were seeing the fdogdal provider used?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the mapguide-internals mailing list
