[mapguide-internals] RE: changing mapguide's image type
Andy Morsell amorsell at spatialgis.com
Mon Mar 5 12:13:17 EST 2007
Trevor,
Are you going to be adding this configuration parameter in RFC 13?  I would
also like to see this be a user config parameter for normal AJAX viewer map
renderings.  This would probably be outside the context of this RFC,
however.  In the sites that I have manually changed this setting in
ajaxmappane.templ, the performance increase has been profound.  I'm afraid
that the default format of PNG, while visually nicer, is causing many sites
to appear much slower than they could be if using JPG.  This is mostly
apparent in cases where the map has imagery layers and PNG transparency has
no advantage.  For instance, a site I just made this switch to, Kids GIS, a
standard AJAX map request resulted in a map image of about 1 MB in size
whereas changing it to JPG results in about 75 KB images.  This has greatly
improved the client experience - but again, does not look quite as nice.
Ideally this parameter would be configurable on a web layout by web layout
basis and not be global site parameter, as it is now.
Thanks for considering this.
Andy
Trevor Wekel wrote:
> Hi Paul,
> Not currently.  It's a hardcoded parameter.  I may be able to add this
> to RFC 13 but it would be a global parameter for the Site Server.  Would
> you also want control over the JPG compressibility?
> Thanks,
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
> Spencer (External)
> Sent: Monday, February 05, 2007 10:25 AM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] changing mapguide's image type
> Hi,
> is it possible to change the image type used by mapguide from PNG to
> JPG?  I thought I saw this option in the system administration tool at
> one point but now I can't find it.
> Also, is it possible to use different image types?  I have a client who
> wants to use tiles and cache imagery as jpg because png is too big, but
> png is better for the rest of the app.
> Cheers
> Paul
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         |
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://www.nabble.com/changing-mapguide%27s-image-type-tf3175664s16610.html#a9315847
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
