[mapguide-internals] Navigation Update
Robert Bray rbray at robertbray.net
Tue Mar 6 00:02:10 EST 2007
Thanks...
My plan is to remove the static menus (and all the duplicated content)
once I am closer to being done. That will push the Navigation menu to
the top of the left nav.
I agree the tabs are sitting low but I don't have write access to the
CSS files. I'll need someone from webcom to help with that.
Bob
Jason Birch wrote:
> Great job Bob, especially working within the confines of a pretty fixed navigation tool.
> The breadcrumbs are cool; I think it's important to support them.
> I think that some of the static menu items will need to be removed to make the area-specific menu bit higher up.
> The tabs are a bit lower than they are meant to be I think:  http://www.spreadfirefox.com/
> Jason
> ________________________________
> From: mapguide-internals-bounces at lists.osgeo.org on behalf of Robert Bray
> Sent: Mon 2007-03-05 7:01 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Navigation Update
> I have started the site navigation update, so bear with me for a bit as
> I am doing it mostly after hours. All changes are based on duplicating
> content, so I wont break anything (famous last words). What's new so far:
> Three Primary Links: Home, Download, and Internals.
> Download has the old content with a slightly streamlined structure.
> Internals links to Trac. In addition the Navigation menu shows up in the
> left side bar with same structure. I really hate the behavior of the
> Navigation menu, but i have not figured out a better scheme for the left
> nav yet that supports the "Home >> Downloads >> You are here" thingy at
> the top of the content.
> Note that Trac has the same three links in it's header and I'll keep
> these in sync as I add more Primary Links in Drupal.
> Anyway, early feedback is welcome and appreciated before I spend more
> time adding additional tabs.
> Thanks,
> Bob
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
