[mapguide-internals] Re: PROJ version 4.5.0
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 19 12:59:02 EDT 2007
Steve, Walt,
Please submit desired changes through the PROJ and GDAL Bugzillas.
I should be able to get the GDAL changes into GDAL 1.4.1, and can
issue a PROJ 4.5.1 with the PROJ changes if desired.
I really think stringent rules should be put in place before
making changes to your local copies of GDAL, PROJ or other
actively maintained third party projects such that the changes
will be sent upstream and their status tracked. Otherwise each
merge is a nightmare.
I also think it is weird that FDO and MapGuide have distinct
copies of GDAL.
Best regards,
Steve Dang wrote:
> Thanks for the info, Walt.
> We will upgrade to GDAL 1.4.0 and PROJ 4.5.0. The latest/original
> sources were already checked in (though I did not see the email
> notification from my SVN r1277 submission for GDAL).
> I did not see any DLL / manifest problem so it was probably fixed.
> I think we should have some process to report all our fixes, including
> the memory leak fixes and additional coordinate systems, to GDAL and
> PROJ so that we do not have to do the code merge every upgrade time.
> Steve.
> _____________________________________________
> ***From:* Walt Welton-Lair
> ***Sent:* Monday, March 19, 2007 5:20 AM
> ***To:* Steve Dang; Frank Warmerdam (External)
> ***Cc:* Bruce Dechant
> ***Subject:* PROJ version 4.5.0
> I noticed that the 4.5.0 version of PROJ is missing some of the fixes we
> made in version 4.4.9 for MapGuide. There are two memory leaks, and
> also some Visual Studio 8 build fixes we made (dealing with manifests).
> I've attached a ZIP file containing the affected 4.4.9 / 4.5.0 files -
> you can compare these and easily see what fixes were made.
> << File: ProjChanges.zip >>
> The zip also has the ChangeLog.Autodesk.txt file that describes all
> changes we made to PROJ.
> If we switch MapGuide to PROJ 4.5.0 we have to re-fix the leaks in the
> code, and make sure the DLL / manifest issue is resolved.
> Frank - can you update the official PROJ source code to at least include
> the memory leak fixes (the fixes to PJ_gn_sinu.c and PJ_laea.c)?
> Thanks,
> Walt
> P.S. Same goes for GDAL. There's a ChangeLog.Autodesk.txt listing all
> changes we made for GDAL 1.3.0. I didn't check to see if our fixes made
> it into version 1.4.0.
> W E @__ __o
> A T R @___ _ \<,_
> L @_ (*)/ (*)
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the mapguide-internals
