[mapguide-internals] Bug in Beta1
Steve Dang
steve.dang at autodesk.com
Fri May 4 16:44:55 EDT 2007
I remember the issue now. With ACE_DEBUG statements, the web tier
outputs information to STD OUT under both debug and release. So, we need
to wrap ACE_DEBUG calls around with #ifdef _DEBUG's. I will fix this.
Steve.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Steve
Dang
Sent: Friday, May 04, 2007 2:14 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Bug in Beta1
We normally use ACE_DEBUG in the Server code only, not in the Web Tier
or Common. Does anyone recall if there is some issue with ACE_DEBUG in
the Web Tier?
Steve.
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Friday, May 04, 2007 2:06 PM
The calls are helpful when running a debug server. They do not appear
when a release build is done. We should not get rid of them.
If these were appearing then somehow a debug DLL was included in the
installer.
Bruce
Dang
Sent: May 4, 2007 2:03 PM
And also this:
ACE_DEBUG((LM_DEBUG, ACE_TEXT( "(%P|%t)
MgSiteManager::Initialize()\n")));
This class is commonly used by both the Server and Web Tier, so we may
want to get rid of these ACE_DEBUG calls.
Steve.
Dechant
Sent: Friday, May 04, 2007 1:53 PM
This only appears if a debug build is being used.
This is the code piece that displays what you are seeing:
ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t)
MgSiteManager::~MgSiteManager()\n")));
Thanks,
Bruce
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: May 4, 2007 12:03 PM
Don't enter a ticket. I'll scan the code real quick tonight, and if I
see the problem I'll add a ticket and fix it.
From: mapguide-internals-bounces at lists.osgeo.org on behalf of
Jason Birch
Sent: Fri 5/4/2007 8:00 PM
Cc:
Ok, after a clean re-install it's not happening.
Should I file a bug anyway? It seems like this shouldn't be
getting
sent to PHP output under normal operations, even if error
reporting is
turned on...
Jason
Jason
Birch
Sent: Friday, May 04, 2007 10:21
Weird. Still doing it in Beta 2 on that server.
Maybe it's a setting in my PHP.ini, an old file from my upgrade,
or an
artifact of running on IIS. I'm going to try a clean install
and see if
it goes away.
J
Subject: [mapguide-internals] Bug in Beta1
... it appears to have been fixed in Beta2, but though I'd send
a note
anyway.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
