[mapguide-internals] Creating MapGuide layer
Haris Kurtagic
haris at sl-king.com
Mon May 7 04:48:18 EDT 2007
Hi Tom,
Sorry for late response I was on the road.
The difference I saw was that when the layer is created from feature
class which has identity, identity properties were not set in the layer
if there were multiple schemas.
If there is just one FDO schema than layer created from the same FDO
class has identity properties set.
Haris
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: 23. april 2007 7:14
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Creating MapGuide layer
Hi Haris,
In Autodesk MapGuide Studio, when a feature source is associated with a
new layer a DescribeSchema is done on the feature source. The layer
does not store the name of the identity property in the layer. The
identity property is always extracted from the schema of the feature
source used by the layer (using DescribeSchema) at "runtime".
The layer stores the name of the schema and feature class (using format
<schemaName>:<featureClass>) in the FeatureName tag of the layer
definition. What behavior differences are you seeing when there are
multiple schemas in the feature source?
Tom
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Saturday, April 21, 2007 2:14 PM
Subject: [mapguide-internals] Creating MapGuide layer
I have ran into issue when layer in MapGuide doesn't have identity
property set.
Layer is created from FDO class which has identity.
It look's like there is different behaviour if provider is returning
multiple schema's.
I would like to debug this (and unfortunately don't have lot of time)
and I was hoping if someone could point me which functions are executed
when Studio is creating layer in MapGuide ?
Haris
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
