[mapguide-internals] 1.2 warnings?
Chris Claydon
chris.claydon at autodesk.com
Mon May 7 12:42:18 EDT 2007
Regarding the new cache directory structure...
When a map definition is modified, all cached tiles are cleared out from
a base folder, so a change to the map will automatically clear out any
tiles using the old path structure, since it shares the same root
folder.
If no resources are modified, it will require a method call to clear the
cache, or the manual deletion of the folder
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: May 7, 2007 10:16 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] 1.2 warnings?
I added the note about changes in the AJAX viewer. Before adding the
part about the cache directory structure changes, I guess I should
confirm whether the old tiles will automatically be removed or whether
the user will need to clear the cache manually.
Were there other changes around the base classes and ASP.Net/Java, or
were those in 1.1?
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: Monday, May 07, 2007 09:01
Thanks for fixing up those pages! We should add those differences to
the release notes page
(http://trac.osgeo.org/mapguide/wiki/Release/1.2/Notes).
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
