[mapguide-internals] Patch: Remove usage of DbXml private header
Tom Fukushima
tom.fukushima at autodesk.com
Fri May 11 16:49:37 EDT 2007
Hi Helio,
Thanks for telling us about what you are doing. I hope that we will be
able to help out wherever possible on what you are doing; and then of
course get any changes integrated back into the project.
Also, if you would like us to post the RPMs that you have as beta, I
think that we can accommodate that.
Cheers
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Helio
Chissini de Castro
Sent: Friday, May 11, 2007 2:17 PM
To: mapguide-internals at lists.osgeo.org
Cc: Jason Birch
Subject: Re: [mapguide-internals] Patch: Remove usage of DbXml private
header
Em ven 11 mai 2007, Jason Birch escreveu:
> Apart from the supported RH rpms and some users struggling through
> trying to build on various platforms, I think this is the first
external
> packaging effort.
Btw, i mentioned wrong. Not jusr on purpose to make RPM, but i already
made
it.
Just i consider it beta, since i'm not completly satisfied and things
can be
change in install procedure.
> What was your motivation to work on this?
First of all i'm doing this because i'm helping Geolinux project in
Brazil,
leaded by Instituto ECOS, INPE and TecGraf.
This project have the intention to add TerraLib on their upcoming TDK
2.0
toolkit support on mapguide ( instead of Geos ) and add TerraLib model
as one
of the FDO providers. ( http://www.terralib.org/ )
As a packager for Mandriva, have this kind of tool working help to fix
other
packages to improve quality of both mapguide and the packages. ( as an
example, xalan-c and xerces-c are just fixed on Mandriva just because
the
work i'm doing on mg and fdo )
And third part is that one of the involved companies need postgis
support on
mapguide, but i'm waiting Mateus finish their work, then i help to add
the
linux part of FdoPostgis.
Among other things ;-)
Of course, before people thinks that i'm talking about bubbles:
http://websvn.geolinux.com.br/viewvc.cgi/
[]'s
Helio Chissini de Castro
KDE Project South America Primary Contact
Curitiba - Brasil
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
