[mapguide-internals] fdogdal, ECW, etc
Tom Fukushima tom.fukushima at autodesk.com
Wed May 23 15:32:31 EDT 2007
Yes, these are problems. I'll post new zip files to straighten things
out.  I'm in meetings right now, but right after that I'll fix this up.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Wednesday, May 23, 2007 1:16 PM
To: 'MapGuide Internals Mail List'
Subject: RE: [mapguide-internals] fdogdal, ECW, etc
I am trying to test 1.2 beta2 with GDAL and MrSID support.  I seem to be
in
dll hell at the moment.  Can someone please clarify which files we are
supposed to have?  Here is what I have right now:
FDO directory:
Gdal13.dll - 1/28/2007 from mg_fdogdal_110.zip
GRFPMessage.dll - 3/5/2007 from mg_fdogdal_110.zip
GRFPOverrides.dll - 3/5/2007 from mg_fdogdal_110.zip
GRFPProvider.dll - 5/23/2007 from GDALPatch.zip
Gdalplugins directory:
Gdal_ECW.dll - 1/27/2007 from mg_ecw_110.zip
Gdal_MrSID.dll - 1/28/2007 from mg_mrsid_110.zip
By the way, GDALPatch.zip has two versions of the GRFPProvider.dll file,
one
in a debug folder and the other in a release folder.  So, if one tries
to
unzip using folders following the directions, the file won't land in the
right spot (unless I'm missing something).  I assume the release version
should be extracted to the FDO directory as I've done above?  Also,
Tom's
instructions indicate to use the mg_fdo_gdal_110.zip file, but there is
also
a gdal_ecw_120.zip on Frank's site - is that one not used?
Thanks very much for the help.
Andy
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam
Sent: Wednesday, May 23, 2007 11:54 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] fdogdal, ECW, etc
Tom Fukushima wrote:
> Hi,
> Yes, the MrSID support works for me.  I had to update the gdal13.dll
> file to the one supplied by Frank though; not sure what's going on
here.
Tom,
Ah, good point.  I had to export a few special symbols from GDAL13 in
order
for the mrsid to work as a plugin as it used internal TIFF interfaces
for
parsing some georeferencing information.
> Anyway here is the note that I added to our FAQ:
> For MGOS 1.2.0 beta 2, after using the mg_fdogdal_110.zip file found
> at http://home.gdal.org/dl/mapguide/, unzip the contents of
> http://download.osgeo.org/mapguide/releases/1.2.0-beta2/GDALPatch.zip
> to C:\Program Files\MapGuideOpenSource\Server\Bin.
Thanks Tom!
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
