[mapguide-internals] .NET: Server-side selecting a feature using MgRenderingService
Maksim Sestic max at geoinova.com
Mon Nov 5 03:34:31 EST 2007
Is there any .NET example on rendering a selection using MgRenderingService,
other than ...\www\mapviewernet\setselection.aspx one? I'm trying to render
a selection and return XML result to a map frame using my custom .aspx
utilizing web services exposed by my application.
This is a part where my code fails:
MgFeatureInformation featInfo = renderingSrvc.QueryFeatures(map, layerNames,
null, MgFeatureSpatialOperations.Intersects, selText, 1, 2);
Response.Write(featInfo.ToXml().ToString());
selText contains MgSelection.ToXml string based on some query.
Alas, featInfo.ToXml returns empty string. What am I doing wrong here?
Regards,
Maksim Sestic
View this message in context: http://www.nabble.com/.NET%3A-Server-side-selecting-a-feature-using-MgRenderingService-tf4750196s16610.html#a13582904
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
