[mapguide-internals] Web API
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Nov 8 14:13:07 EST 2007
Yes, very interrested.
I will have to check up with my company, to see if I can just release
the provider, as it is their property.
I will do that tommorow (im at CET+1).
Regards, Kenneth, GEOGRAF A/S
Paul Spencer skrev:
> Kenneth,
> we (DMSG) have a working MapGuide layer for OpenLayers that has not
> yet been contributed. Are you interested in collaborating on this?
> The person responsible at this end is Mike Adair (cc'd)
> Paul
> On 8-Nov-07, at 2:01 PM, Kenneth, GEOGRAF A/S wrote:
>> As I mentioned, I have been implementing an OpenLayers provider.
>> When dealing with the GETMAPIMAGE the "layernames" are taken as GUID's.
>> This only makes sense when the map is a runtime map, as it does not
>> have GUID's in the MapDefinition.
>> When using the QUERYMAPFEATURES the layernames are the actual names
>> (at least thats how the AJAX viewer sends them).
>> I am not sure that setting the "layernames" parameter actually has
>> any effect.
>> In the AJAX viewer, this line can be found:
>> var reqParams = "SESSION=" + sessionId + "&MAPNAME=" +
>> encodeURIComponent(mapName) + "&SEQ=" + Math.random() + "&SELECTION="
>> + encodeURIComponent(selText) + "&QUERYINFO=" + (requery? "1": "0");
>> Why is the OPERATION parameter missing?
>> The GETMAPIMAGE and GETDYNAMICMAPOVERLAYIMAGE does not seem to
>> re-read a changed runtime map, if the "SHOWLAYERS" or "HIDELAYERS"
>> parameters have not been set, and the runtime map is altered on the
>> server.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals
