[mapguide-internals] OGR Provider and infinite loop
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Nov 8 14:41:03 EST 2007
I have not filed a ticket, I was hoping to fix it myself.
The request completes fine in the OGR Provider, but is then re-called
infinitely and returns the selected feature each time.
I can see the calls being made, and for each call to ReadNext it returns
the feature, then null, then the feature, ... and so on.
I can see that the request being made is the "GetFeatures" operation,
but due to the package passing, I cannot find out where it originates from.
I have traced the "SELECTFEATURES" operation and it also completes, but
right before it sends the result, I get the infinite loop.
Again, I cannot see where it fails.
If the provider is SDF, there is not even a single "GetFeatures"
operation after the SELECTFEATURES (which is how I belive it should be).
I can provide a single MapInfo TAB file, a featuresource and a
querystring that produces the error every time on the current SVN head
(and older).
Regards, Kenneth, GEOGRAF A/S
Traian Stanev skrev:
> It's probably a server issue, if the request to the provider completes fine. I am mystified as to why exactly this happens, if I have a spare cycle, I might take a look. Did you file a ticket for that?
> Traian
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth, GEOGRAF A/S
> Sent: Thursday, November 08, 2007 2:22 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] OGR Provider and infinite loop
> Ok, I will, I just thought of it as a server issue.
> Jason Birch skrev:
>> You might want to post this to FDO-internals?  I know that Traian
>> listens in here, but...
>> Jason
>> From: Kenneth, GEOGRAF A/S
>> Subject: [mapguide-internals] OGR Provider and infinite loop
>> With this new info, can anyone give a guess as to what the problem might
>> be?
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
