[mapguide-internals] Patch for using the MapGuide API with .Net
1.1
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Oct 3 11:42:25 EDT 2007
The motivation I have, is that all the framework applications I use, are
built with .Net 1.1.
It would not be trivial to upgrade those, and simply running them with
the 2.0 framework does not work.
Regards, Kenneth, GEOGRAF A/S
Jason Birch skrev:
> Kenneth, what is the motivation for this patch? Are there sites that
> are unable to install 2.0?
> I would suggest that the trac wiki would be a good place for this kind
> of thing (just tested on a page I maintain on the fdo trac wiki, and it
> allowed uploads of .patch and .zip files). If there are no objections,
> we could create a "Tech Notes" section on the main page and then set up
> a new page "MapGuide with .Net 1.1" for this patch? Or Kenneth could do
> this himself?
> Jason
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of
> Sent: Wednesday, October 03, 2007 04:31
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Patch for using the MapGuide API with .Net
> 1.1
> I have made a patch that enables building a .Net 1.1 version of the
> MapGuide API.
> It should probably not be part of the official release, but I would like
> to share the instructions and binaries with the MapGuide OS community.
> Where can/should I post instructions, diff file and binaries?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
