[mapguide-internals] Cannot create any more connections to the
OSGeo.MySQL FDO provider
Julius Gelšvartas
julius at infoera.lt
Wed Oct 10 02:47:32 EDT 2007
Hello
I have an application which is continuously storing data to MySql using
mapguide featureservice.
I am using MGOS 1.2.
The connection is sometimes established one after another without pauses but
I think I am
closing connections correctly and I get the following
error:
Cannot create any more connections to the OSGeo.MySQL FDO provider.
Exception occurred in method MgFdoConnectionManager.Open at line 256 in file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\com
mon\manager\FdoConnectionManager.cpp
Then after some tine it again starts to work.
Any help would be very appreciated. Thanks in advance.
Julius
Here is the code:
public bool Store(CMsg_Event_GC072 Msg, bool report)
try
MapGuideApi.MgInitializeWebTier(path + "webconfig.ini");
MgUserInformation userInfo = new
MgUserInformation("Administrator", plainText);
MgSiteConnection site = new MgSiteConnection();
site.Open(userInfo);
MgFeatureService featureService =
site.CreateService(MgServiceType.FeatureService) as MgFeatureService;
MgResourceIdentifier fdo = new
MgResourceIdentifier("Library://Lietuva/Connections/Cars.FeatureSource");
MgPropertyCollection properties = new
MgPropertyCollection();
properties.Add(new MgInt32Property("CarId", Msg.Id));
properties.Add(new MgBooleanProperty("KeyOnOff",
Msg.OnOff));
properties.Add(new MgDoubleProperty("Tacho", Msg.Tacho));
properties.Add(new MgInt32Property("RTime", Msg.Time));
MgInsertFeatures insertFeatures;
MgDeleteFeatures deleteFeatures;
MgFeatureCommandCollection featCmdCollection = new
MgFeatureCommandCollection();
if (report == false)
insertFeatures = new
MgInsertFeatures("CarEventsCurrent", properties);
featCmdCollection.Add(insertFeatures);
else
MgFeatureQueryOptions query = new
MgFeatureQueryOptions();
String querystr = "CarId = '" + Msg.Id + "'";
query.SetFilter(querystr);
MgFeatureReader reader =
featureService.SelectFeatures(fdo, "LastAddedEvent", query);
if (reader.ReadNext())
int time = reader.GetInt32("RTime");
reader.Close();
if (Msg.Time <= time)
MgFeatureReader featureReader =
featureService.SelectFeatures(fdo, "CarEventsCurrent", query);
int t = 0;
while (featureReader.ReadNext())
t++;
featureReader.Close();
if (t != 1)
querystr = "CarId = '" + Msg.Id + "' AND
RTime <= '" + Msg.Time + "'";
deleteFeatures = new
MgDeleteFeatures("CarEventsCurrent", querystr);
featCmdCollection.Add(deleteFeatures);
else
MgPropertyCollection prop = new
prop.Add(new MgInt32Property("RTime",
Msg.Time));
MgUpdateFeatures updateFeatures = new
MgUpdateFeatures("LastAddedEvent", prop, querystr);
featCmdCollection.Add(updateFeatures);
MgInsertFeatures("CarEvents", properties);
int t = 0;
t++;
if (t != 1)
else
reader.Close();
prop.Add(new MgInt32Property("CarId", Msg.Id));
prop.Add(new MgInt32Property("RTime", Msg.Time));
MgInsertFeatures("LastAddedEvent", prop);
insertFeatures = new MgInsertFeatures("CarEvents",
properties);
int t = 0;
t++;
if (t != 1)
querystr = "CarId = '" + Msg.Id + "' AND RTime
if (featCmdCollection.Count > 0)
featureService.UpdateFeatures(fdo, featCmdCollection,
false);
return true;
catch (MgApplicationException ex)
Log(ex.GetDetails());
return false;
catch (MgFdoException ex)
return false;
catch (MgInvalidArgumentException ex)
return false;
catch (MgUnclassifiedException ex)
return false;
More information about the mapguide-internals
