[mapguide-internals] RFC 38 - GETDYNAMICMAPOVERLAY
EnhancementsforSelection
Trevor Wekel
trevor.wekel at autodesk.com
Wed Oct 10 12:20:36 EDT 2007
Hi Haris,
Yes. RenderSelection will return the selection only. I did a quick
check on KeepSelection. Setting this true will render the selection
even if the layer containing the selected feature is outside of its
scale range. In other words, a selected parcel will still be visible
even if the Parcels layer is invisible.
RenderSelection = returns the selection image if the object is visible
RenderSelection||KeepSelection = returns selection image even if object
is invisible
RenderSelection||RenderLayers = returns both the selection and the
overlay layers as a single image
I will update the RFC to clarify this.
Thanks,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Wednesday, October 10, 2007 3:49 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] RFC 38 - GETDYNAMICMAPOVERLAY
Hi Trevor,
Perhaps obvious from enumerator names but (I think it could be better if
that would be written in RFC)
If BEHAVIOR is RenderSelection than returned image is selection only?
If BEHAVIOR is RenderSelection||KeepSelection than selection is stored
and will be returned on next get ?
When rendering (pan,zoom,..) viewer will use two requests (on for image
one for selection) instead of one request (if KeepSelection is not set)
While doing this change is it wise to add a parameter for color of
selection.
Haris
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor
Wekel
Sent: Tuesday, October 09, 2007 11:26 PM
Subject: [mapguide-internals] RFC 38 - GETDYNAMICMAPOVERLAY Enhancements
forSelection
Hi everyone,
I would like to submit "RFC 38 - GETDYNAMICMAPOVERLAY Enhancements for
Selection" for review and comments. Please post any feedback to the
list.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc38
Thanks,
Trevor
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
