[mapguide-internals] RFC 53 caching is gooo but how do you flush
the schema cache
Zac Spitzer
zac.spitzer at gmail.com
Wed Aug 13 23:45:52 EDT 2008
I know about the expiry, it's one of those strange things with
mapguide when your programming,
often when you are debugging etc, the provider will of expired since
you last ran your code and
it magically works until you start testing
Does this fall under the scope of RFC 53?
z
On Thu, Aug 14, 2008 at 1:33 PM, Steve Dang <steve.dang at autodesk.com> wrote:
> No, we will need to add a new API for that. Note that an FDO connection / schema cache item will also be automatically flushed when it is expired.
> Steve.
> ________________________________________
> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
> Sent: Wednesday, August 13, 2008 08:50 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] RFC 53 caching is gooo but how do you flush the schema cache
> Is it possible to add the ability to flush the schema cache for a fdo connection
> so far the only way i have found to do it is a server restart or
> touching the feature source
> z
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
