[mapguide-internals] Error in login.php
sergi nistal
serginistal at hotmail.com
Thu Aug 21 13:42:04 EDT 2008
I´ve made a manual install (source code) in debug mode. The version of mapguide is 2.0.1 on Windows Vista and FDO version is 3.3.1. I´m following the guide 'Building MapGuide on Windows' and I´m in step 'Testing the Site Administrator' ('Verifying the Configuration') and in step 'Testing the Web Server Extensions'. The php_MapGuideApid.dll is in C:\MAPGUIDE2\mapguide-2.0.1\Web\bin\debug. Do I have to move the library elsewhere?
Another thing; in the next step ('Running Test Suites') all test are OK except the first (test CoordinateSystem), there are 7 failures. See attach images.
Thanks for all.
> Date: Thu, 21 Aug 2008 23:12:29 +1000
> From: zac.spitzer at gmail.com
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] Error in login.php
> Did you do a standard install? which options did you choose?
> Looks like the web tier can't access php_MapGuideApi.dll
> z
> On Thu, Aug 21, 2008 at 10:50 PM, sergi nistal <serginistal at hotmail.com> wrote:
> > I have that two erros:
> > Error in the step 'Testing the Site Administrator'
> > http://localhost/mapguide/mapadmin/login.php
> > Fatal error: Call to undefined function MgInitializeWebTier() in
> > C:\MAPGUIDE2\mapguide-2.0.1\Web\src\mapadmin\login.php on line 70
> > Error in step 'Testing the Web Server Extensions'
> > http://localhost/mapguide/mapviewerajax/ajaxviewer.php/?WEBLAYOUT=Library://ATest.WebLayout
> > Fatal error: Call to undefined function SetLocalizedFilesPath() in
> > C:\MAPGUIDE2\mapguide-2.0.1\Web\src\mapviewerphp\mainframe.php on line 39
> > Thanks
> > _________________________________________________________________
> > ¡Lo mejor de MSN y Windows Live en tu móvil! Hotmail, Messenger, Spaces… Pruébalo ya y disfruta de todas sus ventajas donde quieras
> > http://serviciosmoviles.es.msn.com/_______________________________________________
> > mapguide-internals mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
¿Preparándote para el verano? En Windows Live Search encontrarás las mejores dietas para conseguir tu peso ideal
http://search.live.com/results.aspx?q=dieta&form=MKTPG
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080821/4ea5253e/1-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080821/4ea5253e/2-0001.jpg
More information about the mapguide-internals
