[mapguide-internals] Intergrating DWF Viewer of MapGuide
Enterprise 2009 into Windows Forms
Carl Jokl
carl.jokl at keynetix.com
Thu Aug 28 09:58:49 EDT 2008
We at the company I work for have considered the possibility of embedding a
browser in the future to use the AJAX viewer. At the moment the system we
are developing uses the DWF viewer due to performance. If you use the AJAX
viewer with something like the Sheboygan example which is just a few layers
and fairly simple then the performance is quite acceptable. For the system
we are using which has many layers and much larger volumes of data the AJAX
viewer becomes so slow it is practically unusable. AutoDesk are saying the
issues with the AJAX viewer are being worked on and hope to make it faster.
AutoDesk are solidly pushing the AJAX viewer. To compound this they are also
planning to stop supporting the DWF viewer. For all it's problems the DWF
Viewer is much much faster for large volumes of data than the AJAX viewer.
View this message in context: http://www.nabble.com/Intergrating-DWF-Viewer-of-MapGuide-Enterprise-2009-into-Windows-Forms-tp19196339p19201162.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
