[mapguide-internals] Problem with "Installing Sample Data and Sample Applications"
sergi nistal serginistal at hotmail.com
Sat Aug 30 14:46:22 EDT 2008
I´m installing a debug version of Mapguide 2.0.1 with FDO 3.3.1 on Windows Vista from source code.
I´m 'Installing Sample Data and Sample Applications' (document with the same name) and when I make image 1 the result is image 2 (paragraph 'Instructions for Loading the Sample Data on the Server'), the result of http://localhost/mapguide/phpviewersample/ajaxtiledviewersample.php is image 3 and the result of http://localhost/mapguide/phpviewersample/ajaxviewersample.php is image 4 (paragraph 'Setting up Sample Applications (PHP) with Apache'), Is everythong ok? Should not bring up a map instead of the whole orange background? Should interrogations appear beside the section of the layers (Islands, Hydrography, ...)? and finally the result of http://localhost/mapguide/webstudio/index.html is image 5,
Should not appear libraries Sheboygan in section 'Site Explorer'?
If you need other data, please contact me. Thank you very much.
_________________________________________________________________
¡Lo mejor de MSN y Windows Live en tu móvil! Hotmail, Messenger, Spaces… Pruébalo ya  y disfruta de todas sus ventajas donde quieras
http://serviciosmoviles.es.msn.com/
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080830/8ab0ee1d/image1-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080830/8ab0ee1d/image2-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080830/8ab0ee1d/image3-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080830/8ab0ee1d/image4-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080830/8ab0ee1d/image5-0001.jpg
More information about the mapguide-internals mailing list
