[mapguide-internals] RE: Berkeley DBXML replication
Tom Fukushima tom.fukushima at autodesk.com
Fri Dec 5 12:17:38 EST 2008
Sorry, this sentence
"The one issue that I see with replication is that MGOS doesn't store everything in the repository."
should have been
"The one issue that I see with replication is that MGOS doesn't store everything in the database."
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: Friday, December 05, 2008 10:14 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Berkeley DBXML replication
There were a couple of emails about this topic...
Jason started with:
I believe that the site server/support server used MapGuide's internal TCP/IP to communicate between the various services.  BDB replication would allow you to run a repository "farm", with a single master and multiple slaves.  Writes all go to one repository, and reads get balanced to the slaves.  Apparently it allows the client software to elect a new master from the slaves if the primary is down too.  This would nicely get around the current problems with load balancing and sessions / server affinity.  I didn't get a chance to look at it in depth, but it seemed to be a good fit.
Zac followed up with:
Jason, your comments about the berkley replication stuff was quite
interesting, but was
that in fact what the old site server / support server stuff was based on?
Some follow up would be good so I'll reply to this best as I can. I've been told that the replication support was investigated a few years ago but the API was quite complex, so we probably just didn't have the resources to do anything here.  Replication was not used for Site/support servers.  The one issue that I see with replication is that MGOS doesn't store everything in the repository.  I would think that everything stored in the DataFiles section would be problematic to replicate; but I'm just guessing here.
Tom
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
