[mapguide-internals] Quotes around halfline and center
Ben Trumbore ben.trumbore at autodesk.com
Mon Dec 15 17:52:29 EST 2008
Zac,
Are you sure it does that?  I checked the style editor code history and the apostrophes have been included since at least mid-2005.  The UI dropdown doesn't show the apostrophes, but it adds them to the layer when you make a selection.
I think the stylization engine is also a bit tolerant of missing apostrophes.  If it fails to obtain a value for what it thinks is a property name, it treats it as a constant string, which in this case has a meaningful value.  Traian can correct me if I'm mistaken.
        Ben
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Monday, December 15, 2008 5:31 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Quotes around halfline and center
Thanks Ben!
So why does studio 2009 insert them without quotes?
z
On Tue, Dec 16, 2008 at 1:59 AM, Ben Trumbore <ben.trumbore at autodesk.com> wrote:
> Zac,
> Most of the stylization elements are defined as FDO expressions.  So,
>        <VerticalAlignment>Halfline</VerticalAlignment>
> says to take the vertical alignment value from a feature property named Halfline, where
>        <VerticalAlignment>'Halfline'</VerticalAlignment>
> declares a constant value for the vertical alignment.
>        Ben
> Sent: Monday, December 15, 2008 3:29 AM
> Subject: [mapguide-internals] Quotes around halfline and center
> Out of interest, what is the reason for having quotes around some of
> the stylisation stuff?
> ie
> z
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
