[mapguide-internals] Quotes around halfline and center
Ben Trumbore
ben.trumbore at autodesk.com
Tue Dec 16 10:00:28 EST 2008
OK, I see that the apostrophes are missing. That isn't correct, but the layer still renders as expected, right? I created a default polygon layer with Studio 2010, and it includes the apostrophes.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Monday, December 15, 2008 5:56 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Quotes around halfline and center
I just created a quick sample layer as a test using studio 2009 and
2.0.2 which is attached
On Tue, Dec 16, 2008 at 9:52 AM, Ben Trumbore <ben.trumbore at autodesk.com> wrote:
> Zac,
> Are you sure it does that? I checked the style editor code history and the apostrophes have been included since at least mid-2005. The UI dropdown doesn't show the apostrophes, but it adds them to the layer when you make a selection.
> I think the stylization engine is also a bit tolerant of missing apostrophes. If it fails to obtain a value for what it thinks is a property name, it treats it as a constant string, which in this case has a meaningful value. Traian can correct me if I'm mistaken.
> Ben
> Spitzer
> Sent: Monday, December 15, 2008 5:31 PM
> Thanks Ben!
> So why does studio 2009 insert them without quotes?
> z
> On Tue, Dec 16, 2008 at 1:59 AM, Ben Trumbore <ben.trumbore at autodesk.com> wrote:
>> Zac,
>> Most of the stylization elements are defined as FDO expressions. So,
>> <VerticalAlignment>Halfline</VerticalAlignment>
>> says to take the vertical alignment value from a feature property named Halfline, where
>> <VerticalAlignment>'Halfline'</VerticalAlignment>
>> declares a constant value for the vertical alignment.
>> Ben
>> Spitzer
>> Sent: Monday, December 15, 2008 3:29 AM
>> Subject: [mapguide-internals] Quotes around halfline and center
>> Out of interest, what is the reason for having quotes around some of
>> the stylisation stuff?
>> ie
>> z
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
