[mapguide-internals] Exception thrown on null values?
Bruce Dechant bruce.dechant at autodesk.com
Thu Feb 28 17:30:00 EST 2008
I don't, just like any other FDO API implementation, but it is at least something that helps with the current implementation.
Is this at the cost of some performance - sure I won't deny that. I wouldn't say that this is penalizing existing providers because the behavior is now consistent in that a MgNullPropertyValueException is thrown instead of unexpected behavior in the past - where the results varied by provider.
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Thursday, February 28, 2008 3:21 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Exception thrown on null values?
How do you know said future provider will implement IsNull() correctly so that you rely on it? The answer is that you can't guarantee anything about future providers -- it's the responsibility of whoever writes the provider to fix it. So penalizing existing providers because of hypothetical future providers doesn't make much sense.
Traian
> internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
> Sent: Thursday, February 28, 2008 5:17 PM
> I agree the provider should be fixed, but what about new providers that
> come out.
> What if they are not as diligent in their implementation? Should the
> server not try to prevent a crash to safe guard this instead of just
> blindly trusting every provider to be perfect?
> Bruce
> Sent: Thursday, February 28, 2008 3:14 PM
> So it will penalize everybody, instead of fixing the provider in
> question to throw an exception when it should?
> Traian
> > Sent: Thursday, February 28, 2008 5:12 PM
> > Yup, but like I said at the cost of stability. :)
> > I would rather do the check then have the server crash.
> > Sent: Thursday, February 28, 2008 3:09 PM
> > Hmm... always doing an IsNull() for everything has an overhead as
> well
> > -- internally to the provider it may be equivalent to getting the
> > property twice. Once to check for null and another time to get the
> > property value.
> > Traian
> > > Sent: Thursday, February 28, 2008 5:05 PM
> > > Jason,
> > > This is the expected behavior as Traian pointed out. This was
> changed
> > > from what it was before because now we do the IsNull() check
> > internally
> > > in the server on all GetXXX() APIs just in case the user "forgot"
> to
> > > call it. This was also done to prevent memory access violations
> when
> > > trying to call for example GetString() from a reader that has a
> NULL
> > > property value and the underlying provider tries to do the read
> > string
> > > and then crashes, by adding this check we have added some server
> > > stability.
> > > Not all providers are created equally. :)
> > > Thanks,
> > > Bruce
> > > internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> > > Sent: Thursday, February 28, 2008 2:48 PM
> > > Am I allowed to say "lame"?  :)  NULL is a perfectly valid value
> for
> > > most data types, and throwing an exception in this case adds a lot
> of
> > > additional processing that should not be required.
> > > I personally feel that this is a case where MapGuide could make
> > > application developers lives a lot easier and improve (slightly?)
> the
> > > performance of web-level apps by swallowing the exception and
> > returning
> > > NULL.
> > > Jason
> > Traian
> > > Stanev
> > > Sent: Thursday, February 28, 2008 13:31
> > > To: 'MapGuide Internals Mail List'
> > > I think this complies with the FDO spec, which requires an
> exception
> > to
> > > be thrown when the value is null and you try to get it anyway. The
> > two
> > > solutions are to check for IsNull() before getting it, or to catch
> > the
> > > exception. The code *could* in theory return NULL in this case,
> > but...
> > > Traian
> [mailto:mapguide-
> > > > Sent: Thursday, February 28, 2008 4:29 PM
> > > > Subject: [mapguide-internals] Exception thrown on null values?
> > > > Hi,
> > > > I'm seeing a case in MGOS 2.0 where MgFeatureReader->GetString()
> is
> > > > throwing an exception when the value of the string is null.
> > > > Is this expected behaviour?  Has it changed since 1.2?  I believe
> > > that
> > > > I've seen a similar error in geometry, but don't have a test case
> > for
> > > > that yet.
> > > > This is relatively easy to work around with a try/catch and
> > > suppressing
> > > > the error output if the message includes "null", but it's a bit
> > > > annoying.  Is there a better way of dealing with this?
> > > > Jason
> > > > _______________________________________________
> > > > mapguide-internals mailing list
> > > > mapguide-internals at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
