[mapguide-internals] Tile caching
Zac Spitzer zac.spitzer at gmail.com
Thu Feb 28 20:08:25 EST 2008
On Fri, Feb 29, 2008 at 11:36 AM, Traian Stanev
<traian.stanev at autodesk.com> wrote:
>  I don't know much about tilecache and WMS-C -- is that the same format as the NASA tiled WMS?
>  http://onearth.jpl.nasa.gov/tiled.html
Pretty much i think but you can teach tilecache about different backends,
the existing tilecache providers live here
http://svn.tilecache.org/trunk/tilecache/TileCache/Layers/
refactoring Mike Adair's openlayers mapguide support into python and
adding auto configuration
of the tile grid using getresourcecontent would be quite straight forward
>  Traian
>  ________________________________________
>  From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
>  Sent: Thursday, February 28, 2008 7:32 PM
>  To: MapGuide Internals Mail List
>  Subject: Re: [mapguide-internals] Tile caching
>  On Fri, Feb 29, 2008 at 4:48 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
>  > Hi...
>  >  I was just looking at Zac's recent ticket about adding cache headers to
>  >  GETTILEIMAGE requests.
>  >  https://trac.osgeo.org/mapguide/ticket/467
>  >  I don't think that this is the best way of presenting our tile caches.
>  >  Personally, I'd prefer to see a direct HTTP interface to the cache,
>  >  where the user requests a file from the webserver as a resource.  That
>  >  way all of the HTTP-goodness (cacheing, etc) is built-in.
>  Tilecache http://tilecache.org/ :)
>  Writing a mapguide rendering backend plugin for tilecache would
>  probably be the easiest effort wise. It
>  would require adding python into the mix, but it's a code base that is
>  already written and working
>  in production.
>  I think going if any changes in this area should adopt existing
>  standards or adopt existing patterns
>  where possible (GETTILEIMAGE and WMS feel a bit like indentical twins
>  separated at birth).
>  >  I don't think that this would be all that hard to do.  There would have
>  >  to be a 404 handler that either generates and sends back images that
>  >  don't exist or, if it is unable to generate the image send the
>  >  appropriate 400- or 500-level codes.  The only problem that I can see
>  >  with this is security.  There would have to be some way for either
>  >  MapGuide to use OS or LDAP security (and the web server to use the same)
>  >  or for the web server to use the MapGuide user store for authentication.
>  >  There was some discussion about MapGuide security earlier (at FOSS4G?)
>  >  and I certainly wouldn't be sad to see MapGuide's proprietary security
>  >  model replaced with something that tied into OS-level security.
>  >  Thoughts?
>  >  Jason
>  >  _______________________________________________
>  >  mapguide-internals mailing list
>  >  mapguide-internals at lists.osgeo.org
>  >  http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>  Zac Spitzer -
>  http://zacster.blogspot.com (My Blog)
>  +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
