[mapguide-internals] RE: Coding Standards
Steve Dang steve.dang at autodesk.com
Tue Jul 15 11:43:56 EDT 2008
The sentence under the "Strings : Across Wire" section:
"The UTF-8 standard will be used for transmitting strings across the wire between any of the MapGuide products (client, web tier, and server)."
should be read as:
"The UTF-16 standard will be used for transmitting strings across the wire between any of the MapGuide products (client, web tier, and server)."
Thanks,
Steve.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, July 14, 2008 1:40 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Coding Standards
Hi all,
I've just finished converting a document Bruce provided which lays out
the standards to be used when working on MapGuide core code.
http://trac.osgeo.org/mapguide/wiki/MapGuideCodingStandards
Comments / corrections welcome.
Jason
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
