[mapguide-internals] RE: MapGuide RFC 51 - Raster Re-projection
Tony Fang
tony.fang at autodesk.com
Wed Jul 16 18:14:02 EDT 2008
I'll change the serverconfig.ini setting to GridSize and place it under the existing RenderingServiceProperties section.
Thanks,
Tony
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt Welton-Lair
Sent: July 16, 2008 12:34 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: MapGuide RFC 51 - Raster Re-projection
GD renderer will (hopefully) soon be removed. I should write a quick RFC for that...
Tony - consider renaming the TileSize parameter to GridSize. We already use the word "tile" in the context of the TileService, and using a different name would reduce confusion.
Walt
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Wednesday, July 16, 2008 2:28 PM
1. Does this feature work with both GD and AGG renders? or just the AGG?
2. To simplify the INI file content, should we have the TileSize property under the RenderingServiceProperties section?
Steve.
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tony Fang
Sent: Tuesday, July 15, 2008 11:36 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] MapGuide RFC 51 - Raster Re-projection
I would like to submit MapGuide RFC 51 - Raster Re-projection for review and comment.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc51
Thanks,
Tony
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
