[mapguide-internals] RFC 50 - Hide Legend Styles
Bruce Dechant bruce.dechant at autodesk.com
Fri Jul 18 14:27:43 EDT 2008
The motivation is not from Studio as Studio cannot do anything about the issue. You have to use the web tier test pages to grab the XML/edit it/ then save it back - I wish Studio could do this for you now, but it cannot.
The motivation is so that the layer definition doesn't have to have style information removed/added whenever you would like to alter the appearance of the legend.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Friday, July 18, 2008 12:11 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RFC 50 - Hide Legend Styles
I originally read the RFC to be a way of fixing unwanted behavior in
MapGuide Studio,
and I suspect that Maksim read it the same way.
Offtopic, I think that Autodesk should fix that problem in Studio, not
in the server.
Ontopic, I think it can be very desireable to be able to select exactly
which elements are visible in the legend.
Even though it might be considered non-logical that some themed elements
are showing up in the the map, and
not the legend, I can see that this is usefull.
The sample case would be having 10 gradient colors for a theming, and
only showing the first and last,
to avoid cluttering the legend.
The RFC looks good to me, and the proposed changes seems right.
I find that the motivation is wrong, and as I see it, tries to address a
problem in MapGuide Studio.
It would not be logical that a user "forgets" what styles they deleted.
Regards, Kenneth Skovhede, GEOGRAF A/S
Bruce Dechant skrev:
> Hi,
> I would like to submit MapGuide RFC 50 - Hide Legend Styles for review and comment.
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc50
> Thanks,
> Bruce
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
