[mapguide-internals] MapGuide Server API implementation
Suggestions
Zac Spitzer
zac.spitzer at gmail.com
Sun Jul 20 10:06:08 EDT 2008
I filed a bug for the ResourceExists not implemented a while ago,
http://trac.osgeo.org/mapguide/ticket/288
If anyone who knows C++ is looking for something easy to start hacking
on mapguide,
this should be quite an easy one to start with
z
On Fri, Jul 18, 2008 at 5:37 PM, Carl Jokl <carl.jokl at keynetix.com> wrote:
> In my recent work with the MapGuide server API I have found that there are a
> couple of items in the implementation I wanted to ask about.
> First the MgResourceService has a method "ResourceExists" or something
> similar but if called it throws a not implemented exception. Are there plans
> to implement this method any time soon? If it were implemented then it would
> allow for checking in advance for resources which might not be present and
> responding if they are not insted of trying to load a resource and
> recovering from the exception thrown if it is not there. Good programming
> practice dictates exceptions should not be used as part of normal program
> flow.
> The second item I wanted to mention was the MgFeatureReader as held inside
> an MgFeatureProperty which is retured after an insert operation has been
> completed. This feature reader does not contain a MgClassDefinition object.
> This has posed a problem in my code because it has the capability to create
> ID object classes (our own classes) using the feature reader by descovering
> the id properties of the feature class and the property types and loading
> them automatically. Not only is it not possible to check what the id
> properties are without the class definition, in addition it looks like
> internally the MgFeatureReader relies on the internal Class definition for
> determining the data type of properties. This means that trying to get the
> data type int identifier for any property from the feature reader causes an
> MgNullReferenceException. Is there a reason why this particular feature
> reader either does not or cannot hold a class definition for the class which
> was inserted. The real use in the returned reader as far as the application
> I am working on is concerned is that for feature classes which have an auto
> generated id the id of the newly created feature can be retrieved after an
> insert. This makes it easy for example to create a new feature and then zoom
> to it on the map.
> View this message in context: http://www.nabble.com/MapGuide-Server-API-implementation-Suggestions-tp18524058p18524058.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the mapguide-internals
