Re[mapguide-internals] building layers in the DWF viewer after
creating a new feature.
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Jul 21 11:26:50 EDT 2008
Is the viewer actually making a server request after you refresh the client? You can use Fiddler (or some other HTTP sniffer) to see if a request gets made. It should be a GETMAPUPDATE request, and it should include a REFRESHLAYERS parameter with the id of the layer you called ForceRefresh on. The response should be an EMap DWF that contains the data for the layer being refreshed. If the request is made and the response has no data for the layer then it's a server error. If no request is made then something is going wrong client-side.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Carl Jokl
Sent: Monday, July 21, 2008 11:17 AM
To: mapguide-internals at lists.osgeo.org
Subject: RE: Re[mapguide-internals] building layers in the DWF viewer after creating a new feature.
Unfortunately I am already calling a force refresh and calling refresh on
the client viewer afterwards. This does not seem to be enough to update the
layer. Even if I call refresh on the map myself manually it doesn't seem to
make a difference. Only when I go to the legend and call a refresh on the
specific layer do the updates get applied.
View this message in context: http://www.nabble.com/Rebuilding-layers-in-the-DWF-viewer-after-creating-a-new-feature.-tp18524613p18570837.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
