Re[mapguide-internals] building layers in the DWF viewer after creating a new feature.
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Jul 22 09:51:18 EDT 2008
Carl - I've attached a document which describes the DWF Viewer EMap API (for your reference).
@others - could we post this information somewhere on OSGeo?
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Carl Jokl
Sent: Tuesday, July 22, 2008 7:06 AM
To: mapguide-internals at lists.osgeo.org
Subject: RE: Re[mapguide-internals] building layers in the DWF viewer after creating a new feature.
Thanks. I am making some progress down this route but have still run into a
problem.
I am not able to figure out what kind of collection the layers's object is.
When I try and index into it like a list using [index] I always get
undefined returned even though using the visual studio debugger I can see
the items contained in this collection. The visual studio debugger also
lists methods for the object relating to adding and removing but not
retrieving an item. I have tried the code as you wrote it with the
"Document.Layers(index)" but this throws an error for me and does not work
at all.
View this message in context: http://www.nabble.com/Rebuilding-layers-in-the-DWF-viewer-after-creating-a-new-feature.-tp18524613p18587042.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
