[mapguide-internals] Dynamic tile rendering proposal
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jul 31 09:02:53 EDT 2008
As I understand meta tiling, it works by creating a larger image than
the one requested (smaller),
in anticipation of requests to similar/adjacent (smaller) images.
In a sense, that is what I want, but I would request the larger image,
and retrieve the sub-tiles.
Unlike meta-tiling, the purpose of this feature is not to create extra
data in advance,
but rather serve a large image in smaller chunks.
If the server renders the entire image and just hands out the smaller
images, I would not
expect the percieved transmission time to diminish, as the crucial part
is the time that goes
before the initial image is displayed.
From a users perspective, a long but visible progress, is better than a
shorter uncertain wait.
(Within certain bounds of course)
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> Kenneth, do you think meta tiling could also solve this problem?
> On Thu, Jul 31, 2008 at 7:20 PM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk> wrote:
>> The current tile mechanism is using static images to serve pre-built images
>> as tiles.
>> For this reason, the tiles are only usefull with "base layers".
>> I have worked with OpenLayers, and it has a very nice tiling mechanism.
>> DM Solutions have built some tiling support into the MapGuide provider for
>> OpenLayers.
>> This uses the static tiles, and the row/column index system in MapGuide.
>> Using the "original" OpenLayers tiling mechanism one can get a dynamic
>> MapGuide image
>> to load as tiles, giving the illusion that the page loads faster (when it
>> actually loads a bit slower).
>> The problem with this method is that MapGuide optimizes the rendered image
>> for the given bounds.
>> This is especially true for calculating label positions and overlaps.
>> I would like to add a parameter for the "GETMAPIMAGE" call that accepts an
>> "outer bounds" parameter.
>> With this parameter, MapGuide should render the extent given by the extent
>> parameter, but use the outer
>> bounds for determining label placements and any other details that may have
>> the same problems.
>> With this, it would be possible for MapGuide to serve tiles from MapGuide,
>> without relying on a
>> static tilcache.
>> I would like to add this as an RFC, but would like feedback on the idea, as
>> well as possible problems.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
