[mapguide-internals] Dynamic tile rendering proposal
Zac Spitzer
zac.spitzer at gmail.com
Thu Jul 31 10:57:59 EDT 2008
I think WMS would work fine for that, if it supported mapDefinitions.
You would call the session resource url
z
On Fri, Aug 1, 2008 at 12:53 AM, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk> wrote:
> Yes, but without storing the cache files, and run on the entire runtime map,
> not just the baselayers.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Zac Spitzer skrev:
>> So like the GETILEIMAGE result via the GETMAPIMAGE parameters?
>> On Fri, Aug 1, 2008 at 12:12 AM, Kenneth Skovhede, GEOGRAF A/S
>>> That might get what I want, assuming that WMS actually handles the
>>> splitting
>>> correctly.
>>> But that would also remove any possibility to work with the runtime map,
>>> which is required
>>> to handle selections, so unfortunately that does not work.
>>> Zac Spitzer skrev:
>>>> How does exposing mapDefinition's as WMS sound as a solution?
>>>> On Thu, Jul 31, 2008 at 11:02 PM, Kenneth Skovhede, GEOGRAF A/S
>>>>> As I understand meta tiling, it works by creating a larger image than
>>>>> the
>>>>> one requested (smaller),
>>>>> in anticipation of requests to similar/adjacent (smaller) images.
>>>>> In a sense, that is what I want, but I would request the larger image,
>>>>> and
>>>>> retrieve the sub-tiles.
>>>>> Unlike meta-tiling, the purpose of this feature is not to create extra
>>>>> data
>>>>> in advance,
>>>>> but rather serve a large image in smaller chunks.
>>>>> If the server renders the entire image and just hands out the smaller
>>>>> images, I would not
>>>>> expect the percieved transmission time to diminish, as the crucial part
>>>>> is
>>>>> the time that goes
>>>>> before the initial image is displayed.
>>>>> From a users perspective, a long but visible progress, is better than a
>>>>> shorter uncertain wait.
>>>>> (Within certain bounds of course)
>>>>> Zac Spitzer skrev:
>>>>>> Kenneth, do you think meta tiling could also solve this problem?
>>>>>> On Thu, Jul 31, 2008 at 7:20 PM, Kenneth Skovhede, GEOGRAF A/S
>>>>>>> The current tile mechanism is using static images to serve pre-built
>>>>>>> images
>>>>>>> as tiles.
>>>>>>> For this reason, the tiles are only usefull with "base layers".
>>>>>>> I have worked with OpenLayers, and it has a very nice tiling
>>>>>>> mechanism.
>>>>>>> DM Solutions have built some tiling support into the MapGuide
>>>>>>> provider
>>>>>>> for
>>>>>>> OpenLayers.
>>>>>>> This uses the static tiles, and the row/column index system in
>>>>>>> MapGuide.
>>>>>>> Using the "original" OpenLayers tiling mechanism one can get a
>>>>>>> dynamic
>>>>>>> MapGuide image
>>>>>>> to load as tiles, giving the illusion that the page loads faster
>>>>>>> (when
>>>>>>> it
>>>>>>> actually loads a bit slower).
>>>>>>> The problem with this method is that MapGuide optimizes the rendered
>>>>>>> image
>>>>>>> for the given bounds.
>>>>>>> This is especially true for calculating label positions and overlaps.
>>>>>>> I would like to add a parameter for the "GETMAPIMAGE" call that
>>>>>>> accepts
>>>>>>> an
>>>>>>> "outer bounds" parameter.
>>>>>>> With this parameter, MapGuide should render the extent given by the
>>>>>>> extent
>>>>>>> parameter, but use the outer
>>>>>>> bounds for determining label placements and any other details that
>>>>>>> may
>>>>>>> have
>>>>>>> the same problems.
>>>>>>> With this, it would be possible for MapGuide to serve tiles from
>>>>>>> MapGuide,
>>>>>>> without relying on a
>>>>>>> static tilcache.
>>>>>>> I would like to add this as an RFC, but would like feedback on the
>>>>>>> idea,
>>>>>>> as
>>>>>>> well as possible problems.
>>>>>>> _______________________________________________
>>>>>>> mapguide-internals mailing list
>>>>>>> mapguide-internals at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the mapguide-internals
