[mapguide-internals] Tile caching
Zac Spitzer
zac.spitzer at gmail.com
Thu Jun 5 23:04:51 EDT 2008
Geowebcache looks like an interesting option in this area
http://google-opensource.blogspot.com/2008/05/accelerate-your-maps-with-geowebcache.html
the actual project website has been down for a while tho
but in order for this to be useful, Mapguide would need to expose
mapDefinitions via WMS, not just layers
z
On Fri, Feb 29, 2008 at 11:08 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> On Fri, Feb 29, 2008 at 11:36 AM, Traian Stanev
> <traian.stanev at autodesk.com> wrote:
>> I don't know much about tilecache and WMS-C -- is that the same format as the NASA tiled WMS?
>> http://onearth.jpl.nasa.gov/tiled.html
> Pretty much i think but you can teach tilecache about different backends,
> the existing tilecache providers live here
> http://svn.tilecache.org/trunk/tilecache/TileCache/Layers/
> refactoring Mike Adair's openlayers mapguide support into python and
> adding auto configuration
> of the tile grid using getresourcecontent would be quite straight forward
>> Traian
>> ________________________________________
>> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
>> Sent: Thursday, February 28, 2008 7:32 PM
>> To: MapGuide Internals Mail List
>> Subject: Re: [mapguide-internals] Tile caching
>> On Fri, Feb 29, 2008 at 4:48 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
>> > Hi...
>> > I was just looking at Zac's recent ticket about adding cache headers to
>> > GETTILEIMAGE requests.
>> > https://trac.osgeo.org/mapguide/ticket/467
>> > I don't think that this is the best way of presenting our tile caches.
>> > Personally, I'd prefer to see a direct HTTP interface to the cache,
>> > where the user requests a file from the webserver as a resource. That
>> > way all of the HTTP-goodness (cacheing, etc) is built-in.
>> Tilecache http://tilecache.org/ :)
>> Writing a mapguide rendering backend plugin for tilecache would
>> probably be the easiest effort wise. It
>> would require adding python into the mix, but it's a code base that is
>> already written and working
>> in production.
>> I think going if any changes in this area should adopt existing
>> standards or adopt existing patterns
>> where possible (GETTILEIMAGE and WMS feel a bit like indentical twins
>> separated at birth).
>> > I don't think that this would be all that hard to do. There would have
>> > to be a 404 handler that either generates and sends back images that
>> > don't exist or, if it is unable to generate the image send the
>> > appropriate 400- or 500-level codes. The only problem that I can see
>> > with this is security. There would have to be some way for either
>> > MapGuide to use OS or LDAP security (and the web server to use the same)
>> > or for the web server to use the MapGuide user store for authentication.
>> > There was some discussion about MapGuide security earlier (at FOSS4G?)
>> > and I certainly wouldn't be sad to see MapGuide's proprietary security
>> > model replaced with something that tied into OS-level security.
>> > Thoughts?
>> > Jason
>> > _______________________________________________
>> > mapguide-internals mailing list
>> > mapguide-internals at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
