[mapguide-internals] Composite Linetypes in Themes
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Jun 26 17:27:57 EDT 2008
What specific error did you get?
The following DLLs depend on MgStylization.dll:
MgRenderers.dll
MgServerKmlService.dll
MgServerMappingService.dll
MgServerRenderingService.dll
MgServer.exe also references it.
It's possible the MGE versions of these DLLs are failing to load against the updated MgStylization.dll. So you could try replacing the above DLLs with the MGOS versions. (Just be sure to backup the original MGE DLLs.)
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Scott Hameister
Sent: Thursday, June 26, 2008 5:00 PM
To: mapguide-internals at lists.osgeo.org
Subject: RE: [mapguide-internals] Composite Linetypes in Themes
DRATS....Double Darn...It did not work...the mapguide Service would not
restart with that new DLL...God i was hoping it would...I have 4 clients
Crawling up my back on this One. Sure Hope they patch this soon.
Walt Welton-Lair wrote:
> Try copying over MgStylization.dll. That's the one which has the relevant
> code.
> No guarantees it will work though.
> Hameister
> Sent: Thursday, June 26, 2008 3:40 PM
> It is MG 2009 where it doesnt work and 2.0.1 OS where it does work
> I guess the reason I posted Here was i was hoping somebody in the OS
> community could tell me if there was a dll or jar file from OS 2.0.1 that
> I
> could take and overwrite in ENT 2009 to fix this problem without any dire
> consequences.
> ANY Answers on that concept?
> PS...Any Composite lines create a big delay...not just themed lines...They
> display when not themed correctly, but the same to create big delays in
> map
> refreshes where they have little or no effect in MGOS.
> But again if there is just a DLL or Jar file I can safely canibalize from
> MGOS it would solve my problem until a bug fix comes out.
> Andy Morsell wrote:
>> What versions of MGOS and MGE?
>> Andy
>> Hameister
>> Sent: Tuesday, June 24, 2008 12:42 PM
>> Subject: [mapguide-internals] Composite Linetypes in Themes
>> Im working with a customer...Im Authoring in Open Source for them and
>> Packaging and then Unpackaging for their Enterprise Install.
>> I have Road Centerlines Themed, and Use composite Lines on Several Of
>> these....The work Excellent in all aspects on Open Source, but in
>> Enterprise
>> they Only Show in the Legend as Composite Lines, They Render as Only the
>> Furthest out of the Composite Settings...Seems to be different Rendering
>> in
>> Enterprise...Also In OS they zoom fluidly..IN Enterprise I get Randor
>> Zoom
>> delays, not even at zoom scale changes...I'm posting this in the
>> Enterprise
>> Discussion Group..But thought it might be a useful Post here...Since this
>> Area Consists of the best people in Both Worlds...Lety me know if its not
>> an
>> appropriate place to post.
>> http://www.nabble.com/file/p18098477/Screenshot.jpg
>> View this message in context:
>> http://www.nabble.com/Composite-Linetypes-in-Themes-tp18098477p18098477.html
>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> http://www.nabble.com/Composite-Linetypes-in-Themes-tp18098477p18141725.html
View this message in context: http://www.nabble.com/Composite-Linetypes-in-Themes-tp18098477p18142369.html
More information about the mapguide-internals
