[mapguide-internals] Fwd: Studio login error with trunk build
(linux) version 7.0.0.1
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon May 12 11:44:40 EDT 2008
I think your error is due to this change: https://trac.osgeo.org/mapguide/changeset/3106. An older version of Studio will not be able to connect to a server which has this schema change applied. Try undoing the schema change in your local copy of the code and rebuild the server / web.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Tuesday, May 06, 2008 8:41 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Fwd: Studio login error with trunk build (linux) version 7.0.0.1
I this to the users list by mistake...
I just built mapguide from the trunk on RH ES 4 and now when i try and
log in with studio 2009 I get the following error
"Unable to complete request from site"
there is an error in xml document (23,4)
using fiddler the xml looks ok, but i did notice the version being
reported as 7.0.0.1 could that be the problem?
I think it's reporting the product version as opposed to the mapguide version,
trunk/MgDev/Common/ProductVersion.h
http://lists.osgeo.org/pipermail/mapguide-users/2007-April/006516.html
2.0 on windows reports
<SiteServer>
<DisplayName></DisplayName>
<Status>Online</Status>
<Version>2.0.0.2308</Version>
The trunk build returns
<SiteServer>
<Version>7.0.0.1</Version>
Otherwise the server is serving maps fine
z
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
