[mapguide-internals] MGOS 2.0.1 status
Zac Spitzer zac.spitzer at gmail.com
Tue May 13 22:20:39 EDT 2008
I just installed 2.0.1 on windows and then updated fusion to the
http://svn.osgeo.org/fusion/tags/fusion-1.0.6/ and it's all working
brilliantly :)
Tiled maps in fusion are reporting the correct co-ordinates in both FF2 & IE7
You will need to uninstall mapguide 2.0 first to test this build
Testing continues...
z
On Wed, May 14, 2008 at 1:49 AM, Chris Claydon
<chris.claydon at autodesk.com> wrote:
> I should be able to do it from here.
> Chris.
> -----Original Message-----
> From: Tom Fukushima
> Sent: May 13, 2008 8:22 AM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] MGOS 2.0.1 status
> Hi Mike,
> If you prepare the 1.0.6 release that sounds good.
> Chris is currently at Where 2.0, but perhaps we can get him to integrate the changes when he has some time. Chris?
> Tom
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mike Adair
> Sent: Tuesday, May 13, 2008 9:12 AM
> Subject: Re: [mapguide-internals] MGOS 2.0.1 status
> Tom,
> I've already fixed the errors that were reported from the 1.0.5 release
> - assuming that the problem with the incorrect coordinates in Firefox
> was just having the warning popup (http://trac.osgeo.org/fusion/ticket/2).
> I've been testing with some of the MapGuide templates with no problems,
> but extra testing by others is always welcome.  The change to the
> templates to remove the fusionError alerts would have to happen in MGOS
> or wherever those live however.
> I could prepare a Fusion 1.0.6 release with what is there now fairly
> quickly if desired.  I could also assist with resolving problems getting
> it integrated with MGOS if needed.
> Mike
> Tom Fukushima wrote:
>> Mike,
>> Before I consider that, what's the time frame for all these fixes,
and will they be tested (for at least basic functionality) on the MGOS
stream before we get them?
>> Tom
Adair
>> Sent: Tuesday, May 13, 2008 8:39 AM
>> Speaking for myself, I would feel a lot more comfortable if MGOS2.0.1
>> shipped with the current 1.0 branch, or preferably if I made a a new
>> 1.0.6 release of Fusion.
>> Also, I'm not sure what end users prefer, but in the MapGuide templates,
>> the fusionError method should remove the alert() call.  This would mean
>> that it would fail silently rather than showing the popup.
>> Zac: how is it broken?  I'm testing tiled and untiled maps in IE and
>> Firefox and haven't encountered any errors yet, but I'm also not testing
>> any redlining functions.
>> Mike
>> Zac Spitzer wrote:
>>> the error about units in fixed in SVN, it is important to remember
>>> that that error relates to getting the tiled maps under fusion to
>>> render with correct co-ordinates. IE now works correctly, Firefox is
>>> broken.
>>> Anyone doing any digitizing, redlining etc with tiled fusion maps with
>>> 2.0.1 will be getting corrupt data
>>> z
>>> On Tue, May 13, 2008 at 12:27 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>>>> Is 2.0.1 expected to resolve the server stability issues with Mapguide?
>>>> On Tue, May 13, 2008 at 8:47 AM, Jason Birch
<Jason.Birch at nanaimo.ca> wrote:
>>>>> Thanks for clarifying... now to find time to test :(
>>>>> Jason
>>>>> From: Tom Fukushima
>>>>> Oops, sorry, I was wrong in my original reply that started this thread.
>>>>> The version of Fusion in MGOS 2.0.1 is Fusion 1.0.4/r1331 (Chris correct
>>>>> me if I'm wrong again). Sorry for the confusion.
>>>>> _______________________________________________
>>>>> mapguide-internals mailing list
>>>>> mapguide-internals at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>>>> Zac Spitzer -
>>>> http://zacster.blogspot.com (My Blog)
>>>> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
