[mapguide-internals] MGOS 2.0.1 status
Tom Fukushima tom.fukushima at autodesk.com
Wed May 14 01:10:39 EDT 2008
Thanks Zac,
We've got the Fusion update in, so we are building with that tonight.  If all goes well, I will post that build as 2.0.1.
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Tuesday, May 13, 2008 8:37 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] MGOS 2.0.1 status
Some feedback from my cartographer,
"rendering with heavy data is much better and it's its showing up
exactly as i want rather than doing its own thing"
z
On Wed, May 14, 2008 at 12:20 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> I just installed 2.0.1 on windows and then updated fusion to the
> http://svn.osgeo.org/fusion/tags/fusion-1.0.6/ and it's all working
> brilliantly :)
> Tiled maps in fusion are reporting the correct co-ordinates in both FF2 & IE7
> You will need to uninstall mapguide 2.0 first to test this build
> Testing continues...
> z
> On Wed, May 14, 2008 at 1:49 AM, Chris Claydon
> <chris.claydon at autodesk.com> wrote:
>> I should be able to do it from here.
>> Chris.
>> From: Tom Fukushima
>> Sent: May 13, 2008 8:22 AM
>> Subject: RE: [mapguide-internals] MGOS 2.0.1 status
>> Hi Mike,
>> If you prepare the 1.0.6 release that sounds good.
>> Chris is currently at Where 2.0, but perhaps we can get him to
integrate the changes when he has some time. Chris?
>> Tom
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mike
Adair
>> Sent: Tuesday, May 13, 2008 9:12 AM
>> Tom,
>> I've already fixed the errors that were reported from the 1.0.5 release
>> - assuming that the problem with the incorrect coordinates in Firefox
>> was just having the warning popup (http://trac.osgeo.org/fusion/ticket/2).
>> I've been testing with some of the MapGuide templates with no problems,
>> but extra testing by others is always welcome.  The change to the
>> templates to remove the fusionError alerts would have to happen in MGOS
>> or wherever those live however.
>> I could prepare a Fusion 1.0.6 release with what is there now fairly
>> quickly if desired.  I could also assist with resolving problems getting
>> it integrated with MGOS if needed.
>> Mike
>> Tom Fukushima wrote:
>>> Mike,
>>> Before I consider that, what's the time frame for all these fixes,
> and will they be tested (for at least basic functionality) on the MGOS
> stream before we get them?
>>> Tom
> Adair
>>> Sent: Tuesday, May 13, 2008 8:39 AM
>>> Speaking for myself, I would feel a lot more comfortable if MGOS2.0.1
>>> shipped with the current 1.0 branch, or preferably if I made a a new
>>> 1.0.6 release of Fusion.
>>> Also, I'm not sure what end users prefer, but in the MapGuide templates,
>>> the fusionError method should remove the alert() call.  This would mean
>>> that it would fail silently rather than showing the popup.
>>> Zac: how is it broken?  I'm testing tiled and untiled maps in IE and
>>> Firefox and haven't encountered any errors yet, but I'm also not testing
>>> any redlining functions.
>>> Mike
>>> Zac Spitzer wrote:
>>>> the error about units in fixed in SVN, it is important to remember
>>>> that that error relates to getting the tiled maps under fusion to
>>>> render with correct co-ordinates. IE now works correctly, Firefox is
>>>> broken.
>>>> Anyone doing any digitizing, redlining etc with tiled fusion maps with
>>>> 2.0.1 will be getting corrupt data
>>>> z
>>>> On Tue, May 13, 2008 at 12:27 PM, Zac Spitzer
>>>>> Is 2.0.1 expected to resolve the server stability issues with Mapguide?
>>>>> On Tue, May 13, 2008 at 8:47 AM, Jason Birch
> <Jason.Birch at nanaimo.ca> wrote:
>>>>>> Thanks for clarifying... now to find time to test :(
>>>>>> Jason
>>>>>> From: Tom Fukushima
>>>>>> Oops, sorry, I was wrong in my original reply that started this thread.
>>>>>> The version of Fusion in MGOS 2.0.1 is Fusion 1.0.4/r1331 (Chris correct
>>>>>> me if I'm wrong again). Sorry for the confusion.
>>>>>> _______________________________________________
>>>>>> mapguide-internals mailing list
>>>>>> mapguide-internals at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>>>>> Zac Spitzer -
>>>>> http://zacster.blogspot.com (My Blog)
>>>>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
