[mapguide-internals] MGOS 2.0.1 status
Tom Fukushima
tom.fukushima at autodesk.com
Wed May 14 19:06:46 EDT 2008
I took the liberty of merging the Fusion code into the branch and then manually setting off a build during the day. The new installers are now posted at the same location as the older candidates: http://download.osgeo.org/mapguide/releases/2.0.1/
Could someone do a test of Fusion? I did some and didn't run into any errors: the measure distance tool still displays distance in degrees for the Sheboygan map :)--- is there a ticket for this?
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: Wednesday, May 14, 2008 9:01 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MGOS 2.0.1 status
It seems that the Fusion update wasn't checked into the 2.0.x stream, so no build today.
Tom
More information about the mapguide-internals
