[mapguide-internals] MapStudio/Maestri returnig error 559 on
postgis provider..
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed May 28 11:48:09 EDT 2008
Ok.
That part is for overriding the coordinate system of the layer.
I have labeled it appropriately for the next release.
It is unfortunate if it doesn't work, but it might be a problem with the
coordinate system in the database.
You should be able to ignore it, and simply save the featuresource
without a coordinate system override.
Regards, Kenneth Skovhede, GEOGRAF A/S
Helio Chissini de Castro skrev:
> On Wednesday 28 May 2008 11:54:12 Kenneth Skovhede, GEOGRAF A/S wrote:
>> Hi Helio.
>> What is the "Fetch coordinates" function?
>> When you create a new layer, can you see the column names?
> No, we barely reach the layer+column stage. The issues happens directly on
> DataConnection creation.
> Attached is two screenshots showing what i mean in the "Fetch coordinates.. "
> button and the error ( on windows he reports an web error 559 ), this is a
> screenshot of mono running in Linux
> []'s
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
