[mapguide-internals] MapStudio/Maestri returnig error 559 on postgis provider..
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sat May 31 14:50:24 EDT 2008
If you can suply me with some form of login (privately, of course), I
can try it out.
Alternatively, I would have to set up an identical environment, to test
it out.
Just so we are clear on the procedure for creating the layer:
1. Click New -> Dataconnection
2. Select "OSGeo Provider for PostGIS", Click OK
3. Enter Database, server, port and login information
4. Click "Test connection"
5. Verify that the test message is "Provider reported no errors"
6. Save featuresource.
7. Click New -> Layer
8. Click the browse button
9. Select the feature source saved in step 5
10. Verify that the tables are listed in the "Schema" dropdown.
If you get this far, everything is working as expected.
If not, you can try the OGR provider in step 2.
If there are no tables in step 10, I expect there to be some setup
required for the PostGIS database.
Regards, Kenneth Skovhede, GEOGRAF A/S
Helio Chissini de Castro skrev:
> On Wednesday 28 May 2008 12:48:09 Kenneth Skovhede, GEOGRAF A/S wrote:
>> Ok.
>> That part is for overriding the coordinate system of the layer.
>> I have labeled it appropriately for the next release.
>> It is unfortunate if it doesn't work, but it might be a problem with the
>> coordinate system in the database.
>> You should be able to ignore it, and simply save the featuresource
>> without a coordinate system override.
> Hi Kenneth
> I just created a clean database ( no data, just pure clean postgis ) and i
> still have errors even trying to create a layer.
> I'm using postgis 1.3.1 over postgres 8.3 running on linux.
> Do you have any sugestion to track the issue if is a postgis provider issue,
> database issue or maestro issue ?
> Thanks in advance
More information about the mapguide-internals mailing list
