[mapguide-internals] MapGuide Open Source 2.1 -
whereisthecontinuous integration system ????
Haris Kurtagic
haris at sl-king.com
Fri Nov 14 08:52:37 EST 2008
I believe that we in SL-King ( Davor Klemen) could put time to help to
create and manage windows installations.
WiX looks like nice way to go.
Jason, Davor will look into projects you already did and try to get
familiar with MG/WiX.
If you already have ideas/tasks for further steps, we are all ears :)
Haris
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Friday, November 14, 2008 11:18 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MapGuide Open Source 2.1 -
Trevor, all,
I spend a bunch of time playing with Visual Studio setup packages, and
was pretty underwhelmed. Seems like a good solution for something
small, but not for what I would eventually want from the MapGuide
installer.
I also spent a few hours familiarizing myself with WiX, which seems to
be a pretty decent solution. When combined with something like a
modified version of Paraffin (allows automated import of file references
given a source directory), I think it would meet our needs quite
handily, and allow room in the future for more advanced stuff.
If anyone's interested, my WiX 3 VS2008 project is available here:
http://www.jasonbirch.com/temp/mginstall/MgInstaller.zip
And the MSI I created while goofing around (it basically just installs
FDO) is here:
http://www.jasonbirch.com/temp/mginstall/NotMapGuideOpenSource-0.0.1.msi
(9.5MB)
WiX (Version 3 is in beta but already far better than 2):
http://wix.sourceforge.net/
Paraffin (we'd want to update for WiX3):
http://www.wintellect.com/CS/blogs/jrobbins/archive/2008/07/11/paraffin-
1-04-a-new-switch-and-easier-updates.aspx
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor
Wekel
Sent: Thursday, November 13, 2008 15:48
Subject: RE: [mapguide-internals] MapGuide Open Source 2.1 - where
Perhaps Tim can chime in here but there may be a few holes with simply
using the existing build/install scripts for open source:
Autodesk uses BuildForge internally and OsGeo is using BuildBot. The
existing build scripts may not be BuildBot compatible. The open source
community may need to adapt/modify the existing BuildForge scripts to
work with BuildBot.
The Windows installers for open source use InstallShield. Unless
someone wants to purchase one or more InstallShield licenses, we will
not be able to use the existing open source installers. I have
suggested using Visual Studio deployment projects as an alternative. I
took a brief look at the Visual Studio deployment projects a while ago
and they seemed to have enough features.
Tim already has RPM configuration files available for RedHat Linux. It
may be possible to adapt these for use with other distributions.
If we want to get the open source builds moving on Windows, here is an
initial set of tasks:
1. Set up a publically accessible Windows build machine with Visual
Studio installed
I should be able to do this by early next week. However, there is a
restriction. Visual Studio is licensed by user so maintainers should
purchase their own copy of Visual Studio Standard (or higher). Ideally
we should use the "build" machine as a build machine and not an
installer development box.
http://download.microsoft.com/documents/useterms/Visual%20Studio_2008%20
Standard%20Edition_English_4c240268-8ee9-4cf3-96cf-3bd5ef02a81f.pdf
Item 1 b) specifically states "per user"
2. Obtain the current open source Windows build scripts from Tim and
investigate whether they are appropriate for BuildBot.
3. Start looking at installer technology for the Windows builds. The
Server install will be easier than the Web Extensions install. Visual
Studio may be sufficient. InstallShield would be a more expensive
option but is guaranteed to work. As far as I know, InstallShield is
also a user based license.
Anyone interested in looking into items 2 or 3? We can add additional
items for the Linux distros (cmake, rpm config files, etc) but I will
not have time to set up multiple VMs by next week. I suspect the
community would prefer to see the Windows installs working before we
tackle the various Linux distros.
Thanks,
Trevor
________________________________________
[mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: Thursday, November 13, 2008 4:03 PM
Subject: RE: [mapguide-internals] MapGuide Open Source 2.1 - where is
Hi Jason,
Comments inline...
Tom
Birch
Sent: Thursday, November 13, 2008 3:20 PM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] MapGuide Open Source 2.1 - where is
Tom,
We should be careful to distinguish between continuous builds (a
development tool) and packaging (a user service). IMHO, packaging is a
much more critical issue at this point.
>>> Continuous builds or builds of some sort are required for the
packaging. The two are required and if we are going to do builds, we
should just do it right. What's to be careful about here, let's set out
what needs to be done (RFC), and do it.
Autodesk's resourcing issues had come up a couple times, but the
potential disavowal of responsibility for packaging is news to me, and I
would imagine most of the users on the public mailing lists.
>>> The build team here does all parts of the build and this includes
packaging.
I think that by keeping the installer process closed source, Autodesk
essentially committed to maintain the open source installer packages
right from the start. Without installers you may have an open source
application, but no chance of building a project/community.
>>> There is nothing being kept intentionally under wraps here. Tim has
always told me he's ready to give the scripts to anyone who needs them.
The mgos community may be strong enough to take on the challenge at this
point, but I feel that some support from Autodesk (even if its just a
list of files, registry keys, conf file setting, permissions, etc) is
critical to moving the packaging process out as a community
responsibility. I don't have the visual studio expertise to create the
setup project, but I would be happy to take on the role of package
creation for new MGOS releases if I can get some help setting this up.
>>> I would hope the community can take this on. It's been over two
years since our first release. Scripts are available from Autodesk.
I don't know what to do about Linux packaging. Without the adoption of
the cmake build process, I have absolutely no interest in even looking
at this.
>>> We have never packaged for Linux. We've only provided the source
tar package for that particular release. It would be good to address
this as well.
Jason
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
