[mapguide-internals] RE: CSMap in OEM.sln
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Nov 17 17:57:48 EST 2008
I think CSMap should be added to Oem.sln.
For the FDO error, the MG file hasn't changed in many months, nor has the IBaseSelect.h FDO header. I build against G025 without error. I suspect something is amiss on your machine.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, November 17, 2008 5:49 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] CSMap in OEM.sln
I was trying to build from trunk, and found that I had to compile CSMap
individually. Should this be added to the OEM sln? Should I enter a
ticket?
Also, I'm getting an odd error when trying to build trunk against FDO
G026:
1>.\GwsPreparedFeatureQuery.cpp(229) :
error C2660: 'FdoIBaseSelect::SetOrderingOption' : function does not
take 2 arguments
Has anyone else seen this? It's quite possible that my environment is
messed up with too many FDOs.
Jason
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
