[mapguide-internals] RE: CSMap in OEM.sln
Jason Birch
Jason.Birch at nanaimo.ca
Mon Nov 17 18:59:18 EST 2008
Thanks Hugues.
I'm not nearly competent enough to be messing with .sln files, but I'll
add that info to the ticket I'm about to submit...
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Hugues
Wisniewski
Sent: Monday, November 17, 2008 15:52
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: CSMap in OEM.sln
Hi Jason,
If you add CSMap to Oem.sln you might be interested in the post build
steps located in the CSMap solution
That solution builds the dictionary compiler and then builds the
dictionaries automatically.
Building the dictionaries is done automatically in release mode only to
speed up the time in debug environments, since the source dictionaries
are not updated very often.
So, if that post build step is added, that also means the dictionary
compiler would need to be added to oem.sln
Hugues
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: Monday, November 17, 2008 2:58 PM
I think CSMap should be added to Oem.sln.
For the FDO error, the MG file hasn't changed in many months, nor has
the IBaseSelect.h FDO header. I build against G025 without error. I
suspect something is amiss on your machine.
Walt
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Monday, November 17, 2008 5:49 PM
Subject: [mapguide-internals] CSMap in OEM.sln
I was trying to build from trunk, and found that I had to compile CSMap
individually. Should this be added to the OEM sln? Should I enter a
ticket?
Also, I'm getting an odd error when trying to build trunk against FDO
G026:
1>.\GwsPreparedFeatureQuery.cpp(229) :
error C2660: 'FdoIBaseSelect::SetOrderingOption' : function does not
take 2 arguments
Has anyone else seen this? It's quite possible that my environment is
messed up with too many FDOs.
Jason
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
