[mapguide-internals] RE: CSMap in OEM.sln
Jason Birch Jason.Birch at nanaimo.ca
Mon Nov 17 19:33:24 EST 2008
Answering my own question:
set MENTOR_DICTIONARY_PATH=D:\OSGeo\mapguide\Oem\CsMap\Dictionaries
mgserver run
works!
Thanks again,
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Monday, November 17, 2008 16:28
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] RE: CSMap in OEM.sln
Thanks Hugues.
It's a Windows build, and I don't have that env var set.  Also, it
doesn't look like the dictionaries are copied into the MapGuide
Server/bin structure as part of the Server post-build like FDO is; I
wonder if they should be.
I'm guessing that the built dictionaries (are those the *,mrt files?)
are built in place at my local copy of:
http://svn.osgeo.org/metacrs/csmap/trunk/CsMapDev/Dictionaries/
and the env var should point there?
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Hugues
Wisniewski
Sent: Monday, November 17, 2008 16:13
Hi Jason,
The location of the coordinate system dictionaries is given by the
system variable MENTOR_DICTIONARY_PATH
So, if this value is not defined or points to another location that the
one required, that might be the cause of the error.
Or the dictionaries are simply not built
Is it a Windows build? Linux?
Hugues
Birch
Sent: Monday, November 17, 2008 3:56 PM
Oh, thanks Brent, Jack.
That seems to have got me past that error and everything compiles fine
and installs to Server/bin/release (after I copy FDO into Release for
the xcopy process).
Now when I try to start mgserver, I'm getting:
<2008-11-17T15:38:10>   2968
 Error: The coordinate system initialization failed.
 StackTrace:
  - MgServer.open() line 849 file
d:\osgeo\mapguide\server\src\core\Server.cpp    The coordinate system
I'm guessing that either:
 - some required files aren't being copied to the server/bin/release
folder in the Server's post-build OR
 - I'm missing an environmental variable or something else required for
CSMap
Any ideas?
Thanks,
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jack
Lee
Sent: Monday, November 17, 2008 15:17
Subject: [mapguide-internals] RE: CSMap in OEM.sln
Hi Jason,
Brent Robinson has problems sending the email. Below is his responds:
Sent: Monday, November 17, 2008 6:09 PM
To: 'mapguide-internals at lists.osgeo.org'
Subject: FW: CSMap in OEM.sln
Hi Jason,
The error in G026 will be fixed in G027.
For G026, it can be worked around by getting
providers/SHP/inc/IExtendedSelect.h and copying it to your G026 inc/SHP
directory.
Brent.
Birch
Sent: Monday, November 17, 2008 5:49 PM
Subject: [mapguide-internals] CSMap in OEM.sln
I was trying to build from trunk, and found that I had to compile CSMap
individually.  Should this be added to the OEM sln?  Should I enter a
ticket?
Also, I'm getting an odd error when trying to build trunk against FDO
G026:
1>.\GwsPreparedFeatureQuery.cpp(229) :
  error C2660: 'FdoIBaseSelect::SetOrderingOption' : function does not
take 2 arguments
Has anyone else seen this?  It's quite possible that my environment is
messed up with too many FDOs.
Jason
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
