[mapguide-internals] Help needed with Ubuntu build error with DWF
Zac Spitzer zac.spitzer at gmail.com
Fri Nov 21 04:55:26 EST 2008
root at zserver:/home/zac/mapguide-trunk/Oem/DWFTK7.1/develop/global/build/gnu/dwftoolkit#
cat build_setup.sh #
#! /bin/bash
cd ../../../src/dwf
tar -xzf ../../build/gnu/dwftoolkit/build_files.tar.gz
rm -rf autom4te.cache/
autoreconf --force --verbose
./build_setup.sh
autoreconf: Entering directory `.'
autoreconf: configure.in: not using Gettext
autoreconf: running: aclocal --force
autoreconf: configure.in: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./ltmain.sh'
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.in and
libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree.
libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
autoreconf: running: /usr/bin/autoconf --force
autoreconf: running: /usr/bin/autoheader --force
autoreconf: running: automake --force-missing
configure.in:10: required file `./config.guess' not found
configure.in:10: required file `./config.sub' not found
autoreconf: automake failed with exit status: 1
ls -l
total 100
-rw-r--r-- 1 zac zac 87364 2008-11-21 11:07 build_files.tar.gz
-rwxr-xr-x 1 zac zac   147 2008-11-21 20:52 build_setup.sh
-rwxr-xr-x 1 zac zac   277 2008-11-21 11:07 pack_build_files.sh
did i do it right? is that anyhelp?
z
On Fri, Nov 21, 2008 at 8:29 PM, Helio Chissini de Castro <helio at kde.org> wrote:
> On Sexta 21 Novembro 2008, Zac Spitzer wrote:
>> before that ACE compiles ok and i did the whole linuxapt stuff without
>> problem
>> any quick way to test the bork factor?
>> z
> Go for an manual test.
> enter in  mapguide-2.0.2/Oem/DWFTK7.1/develop/global/build/gnu/dwftoolkit
> open build_setup.sh and change autoreconf to use verbose
> the run ./build_setup.sh as usual
> []'s
> KDE Developer
> Brasil/South America Primary Contact
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
http://ennoble.dreamhosters.com/mapguide-central/
+61 405 847 168
More information about the mapguide-internals mailing list
