[mapguide-internals] Autodesk.MapGuide.Studio.Site.LayerInfo.Save
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Nov 24 07:58:16 EST 2008
The Autodesk Studio comment is most likely to be acted upon, if you send
it directly to Autodesk.
Where do you see the slowdown without the cultureinfo?
Maestro only uses the mapagent.fcgi wrapper, and the web.config is .Net
related, so they should not affect each other.
Regards, Kenneth Skovhede, GEOGRAF A/S
ljv skrev:
> I find this (Autodesk.MapGuide.Studio.Site.LayerInfo.Save) functions slow,
> 2-4 seconds to save 2kb.
> There is no problem with server or network, most functions are fast.
>  Except for this: In web.config globalization Culture="xxxx" must be set.
> Unless the culture is explicite set all strings functions like search become
> so slow that the application is useless. Both maestro and mapstudio benefit
> from adding culture to web.config. we have used our culture="sv-SE" and
> English variants and setting the culture speeds the viewer and application.
More information about the mapguide-internals mailing list
