[mapguide-internals] Tweaking serverconfig.ini defaults for 2.1
Jason Birch
Jason.Birch at nanaimo.ca
Wed Oct 8 12:52:10 EDT 2008
In general, I think it would be a good idea to tweak the settings for a
more "normal" installation where you see lots of layers, etc. This
would go a long way towards addressing some of the performance
complaints. Ideally, people would take the time to configure MapGuide
for their expected load, secure it properly, etc, but I doubt this is
all that common.
I think the main problem with not excluding these providers is running
into locking issues when trying to edit the files via MapGuide. I don't
think that this is a common use though. Perhaps including them, and
providing documentation on requirements for editable layers would be a
better choice.
I think someone (Dave Wilson maybe?) proposed setting up two references
to the providers, one of which wasn't excluded, and only using the
excluded version on RW data sources. I haven't tested this though.
Jason
-----Original Message-----
Subject: [mapguide-internals] Tweaking serverconfig.ini defaults for 2.1
What do people think about tweaking the defaults for serverconfig.ini?
My understanding is that the CacheSize=100 setting is a bit small for
everything beyond a few basic maps
Also what about the SDF & SHP with DataConnectionPoolExcludedProviders
More information about the mapguide-internals
